ALFA ROMEO SAFE CODE FOR RADIO
Username: Ar156jtd
Hello, I have a problem with my radio car in my alfa 156. Suddenly, her ask me a safe code, i didn't disconnect any cable (batterie or other). The problem, I am the third owner and the previous owner did not give me the code card for radio.
Is anybody can help me ?
The reference is :
ALFA ROMEO 156 2.4 JTD 2003
Travel pilot Alfa 156 RNS4
Prod NR FIAT 1560342100
Serial 881BP149126523845
BP nr 7612001497
Thank you for your help
Username: Regrooster
Post Number: 10195
try code 5164
Username: Ar156jtd
Thank you for your help. I tried the code but it did not work. This is not the correct code.
Post Number: 10210
Try code 1988
Username: Ar156jtd
I don't believe that it is this code because in the user's manual, it is written that the code is composed of 4 digits between 1 to 6.
thank you nevertheless
Post Number: 10219
Then it must be 5164
Username: Ar156jtd
I tried the code 1988 and it works. Thank you very much. But there are some thing I did not understand, in the user manual it is written that is a 4 digit code from one to six.
Thank you very much
Post Number: 10236
Perhaps the radio has been changed and is not the original one fitted in the car when it left the factory
OR
It's the wrong manual for the radio
Username: Wysourek
Hello,my car alfa romeo 1.9 jtd 2005
VIN: ZAR93200000259346
Please key my original radio.Thanks
Post Number: 10438
Username: Wysourek
ALFA
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
