Radio code for Alfa Romeo 147
Username: Alex5114
Hi,
I need help, I'm looking for the code of my Alfa 147 autoradio. My autoradio is a connect nav+ wich brand is magneti marelli. There are several number write on the autoradio.
IMEI : 500 101 110 170 410
Other number : 735329871.
Last number between bar code : 3TGC05K5D.
Thanks for your help
. Upload
Username: Regrooster
Post Number: 10380
Sorry....will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code
It will not be available for free or cheap from anywhere on the Internet
Username: Alex5114
Hi, thanks for information. I ask the code to Alfa roméo, but it's to expansive. Nobody knows a site or someone who can give the code for a connect nav+.
thanks
