Blaupunkt 520 security code
Username: Garycon06
BrisbaneAustralia
Hi all,
I have a '03 holden astra with blaupunkt 520 radio, I'm after the security code please. The serial number is bp839124742584. I would really appreciate some help.
Cheers
Username: Regrooster
Post Number: 10351
try code 1539
Username: My898
Hi Reg Rooster,
Can you please help with a security code for my Blaupunkt 520?
Serial No. BP2391 3 0797043.
No. 92 057 951
Disconnected battery sometime ago have previous codes from Holden for Astra 2002 didn't work.
Cheers
Post Number: 10360
my898
BLAUPUNKT
Try code 6709
Username: Even65
Hi , I have a 2005 astra vin number W0L0TGF485G078576 and need the radio code. Can you help, Thanks Glenn
Post Number: 10408
Glen
VAUXHALL
Sorry....will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code
It will not be available for free or cheap from anywhere on the Internet
Username: Even65
Hi, it is a holden astra 2005. Do I need to remove the radio to get the serial numbers?
Post Number: 10416
If you remove the radio and quote all the details then this can be checked .
If it is a BLAUPUNKT radio then a code may be possible but on most occasions it is either a Philips (VDO) or Grundig and a 2005 HOLDEN (GM ) is normally too new for the database so Main Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code
Username: Kizo
Hello, I saw this forum and hoped you could help with my
code as well.
blaupunkt
AUZ1Z3A9607422
thanks
Post Number: 10443
AUZ1Z3A9607422 ..........Username: Kizo
Username: Kizo
tnx Regrooster
