Renault radio code please
Username: Hariboy23
Hello, i need a radio code for my Renault i've just bought. Any help greatly appreciated. Sorry if its info overload but i've written everything i found below:
7700 433 943
Philips 22DC461/62P
9022 214 61628
Pa4Bis, 4*15W, RDS
FD 11 99 33 8024865
Model No. 22DC461/62P
Sticker: Code "gravage" and 8024865
Sticker on the side:22DC461/62P
902221461628
MCH024788
Engraved on the side:
RN461FX8024865
Thanks for your time and trouble.
Username: Regrooster
Post Number: 10313
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
Username: Hariboy23
Hello i've taken another look and the only other codes i can see don't follow the format of the security code above. I've listed them in case anyone can help.
Barcode:
7700 433 943 0784
The number 276 in a diamond
a kind of chart with 6 boxes, each labelled with letters, only 2 have numbers in them
C177 - the 177 is a kind of stamp
M151 - the 151 is a kind of stamp
finallly a label with a feint 176 is printed on a strip.
Sorry its vague.
Thanks again
Username: Hariboy23
Sorry the barcode should be
7700 433 943 o784, getting confussed with "oh's and Zero's", its a letter o followed by 784.
Username: Vivian1000
Please help
Code needed for Renault scenic megane s reg.
Details.RENAULT radiosat 6000
7700 433070 R573
Philips 22DC481/62
FD109839 9015969
Product 1098399015969
Many many thanks!
Username: Elektron1234
Poland
Post Number: 244
hariboy23
code is 1271
contact me:
e-mail-stanislawgoclon@o2.pl
Poland
Post Number: 247
Vivian1000
code is 8463
contact me:
Username: Nerac47
Hi, I've just bought a Renault Scenic, but the radio is not working and i don't have the code. Hoping someone may be able to help.
Serial Number: RNRD0340222725
Security Number: 8200300858TJ998
Product Number: FD0704430222725
Model No: REN RDW131-10
THANKS
Nerac47
Post Number: 10329
Nerac47
RENAULT
Try code 6197
Username: Nerac47
THANKS SO MUCH Reg, That code worked a treat. You guys are simply amazing. It's like a magic wand! Not sure how you do it but THANKS. It's truly appreciated!!! Noelene
Username: Davedee
i need a radio code 4 my laguna 1999 details -fd1299299228172 serial no rn481fx9228172 bar code 7700 433 070 5272 other no 9022 214 81629 model philips 22dc481/62 many thanx dave
Username: Lawman1962
Reg Rooster
Code worked fine. Thanks a million.
Post Number: 10339
davedee
Username: Davedee
Davedee posted on Monday, May 07, 2012 - 17:49 GMT
Username: Davedee
sorry wrong bar code its 7700-433-070-s272 only other number is m/ch 227884 thanx dave
Poland
Post Number: 248
davedee
code is 7787
contact me:
Username: Davedee
thanx so much elektron av a good day davr
Username: Extreme89
Hi, I've just bought a Renault megane convertible 55plate 1.6 16valves, but the radio is not working and i don't have the code. Hoping someone may be able to help
Serial Number: RNRD6950217012
Security Number: 8200483757TK098
Product Number: FD0405330217012
Model No: REN RDW240-00
Poland
Post Number: 258
extreme89
Your code is 5968
contact me:
Username: Panzerhansa
barcode 8200002607
model no 22dc276/62z
prod no fd0101400157055
other no tov345
rn279f10157055
bt2
Hope this is enough
Poland
Post Number: 261
Then post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
off of the radio
all I got + a number on a sticker on the other side 0157055 Upload
