New member Username: StephbenPost Number: 1 Registered: Apr-12 | Bonjour Suite à un changement de batterie, mon autoradio me demande le code et je ne l'ai pas ! On m'a conseillé de venir vers vous, je vous donne ma réf : bmw business rds 65128374683 (je vous joins une photo pour les autres réf si besoin ) merci d'avance ![]() |
Silver Member Username: BogegeBG Post Number: 443 Registered: Dec-10 | Very bad picture! Stephben maybe 5456 |
New member Username: StephbenPost Number: 2 Registered: Apr-12 | re-bonjour Oui je suis désolé pour la photo! Merci j'ai essayé 3 fois et maintenant il dit "code wait" Faut-il entrer le code à 4 chiffres et attendre ? |
Silver Member Username: BogegeBG Post Number: 446 Registered: Dec-10 | Read here for code entry help:http://www.dndservices.co.uk/search.php?mode=search&page=1 |
Silver Member Username: BogegeBG Post Number: 447 Registered: Dec-10 | Stephben read here for code entry help:http://www.dndservices.co.uk/search.php?mode=search&page=1 |
New member Username: Mac100Post Number: 1 Registered: Apr-12 | hi.can anybody help me lost radio code for my 03 corsa model no is gm020531804410 thanks |
New member Username: StephbenPost Number: 3 Registered: Apr-12 | Bogege, j'ai trouvé un autre numéro gravé : 65128374683 ph 7850 V12 458 10 si ça peut aider....(le code 5456, essayé 5 fois, c'est pas bon...) merci d'avance ! |
Platinum Member Username: RegroosterPost Number: 10295 Registered: Aug-08 | PH7850V1245810 = 5395 |
New member Username: StephbenPost Number: 4 Registered: Apr-12 | Merci beaucoup, ca marche !!!!!!! |
Platinum Member Username: RegroosterPost Number: 10300 Registered: Aug-08 | stevemac New member Username: Mac100 Post Number: 1 Registered: Apr-12 Mac100 posted on Sunday, April 29, 2012 - 19:06 GMT hi.can anybody help me lost radio code for my 03 corsa model no is gm020531804410 thanks ============================ BE PATIENT ! Duplicate post....Already answered Please do NOT post the SAME request in more than ONE thread It is not necessary....and can cause confusion |
