Home Theater 5.1 Speakers (Budget)
Username: Amythompson172
Hello there! Im a new homeowner and trying to fill my house with objects, instead of empty space. I thought the home theatr system would be a good idea considering I love my movie and TV watching experience! I dont really know much about this stuff, so any advice is just fantastic! I'm not made of money, so the budget for the full home theatr area should be capped near $1000.asd
I decided to start with the speakers, and build up from there... I did some research and whatnot, and i found this set here:
Onkyo HT-S3400 5.1-Channel Home Theater System - http://www.amazon.com/gp/product/B004O0TRDI
Is this a good bang for my buck, while keeping in mind my total budget?
Amy
Username: Project6
Post Number: 15918
Hello Amy. Does your $1000 cap include the TV and DVD player? Or is that just for the receiver and speakers?
Username: Edison
Glendale, CA US
Post Number: 953
Amy, if you stick with 2 channels (2 speakers and a stereo receiver), then you would end up with better quality.
I listen to 2 channel system, and I don't miss other channels at all.
Your ears will thank you if you go this rout. All in one system like the Onkyo on Amazon will hurt your ears, and give you listening fatigue.
Not an enjoyable experience. Frankly, $1000 won't buy very much quality if you want surround sound - but if you swtich over to stereo (2 channels), then you will get something that sounds better for sure.
Let us know if you choose this path, and you will get good suggestions on what to buy.
Username: Project6
Post Number: 15951
My experience with trying to convince the newer generation that great stereo is better than mediocre surround sound is much like trying to convince a person to pull pull their own teeth.
Username: Vm8444
TorontoCanada
Post Number: 422
http://www.amazon.com/Denon-AVR-1709-7-1-Channel-Multi-Zone-Receiver/dp/B001BKLC5K
http://www.amazon.com/Energy-Classic-Theater-System-Black/dp/B001202C44
Username: Einteractive
Well, there are many brands available for home theater systems like Sony and Samsung from which you can easily buy in your budget. However, it would be best to research online for more better options.
Need to Register?
Forgot Password?
Enable HTML code in message
