Radio code CLIO
Username: Mpt1981
Hi guys. Had a fuse go on my headlights, but pulled radio fuse instead... :-(
Its a 03 plate clio 1.2 "expression"
information from the side of the radio -
Model no - 22DC278/62B
TOW367
RN278F30489121
PROD NO - FD0403220489121
820057681TW367
8200 057 681
Hope ive got all the information needed. A massive thank you in advance...... You dont realise how much you miss the radio, untill you realise your a really bad singer!!
Username: Bogege
BG
Post Number: 393
Mpt1981 try 3603
Username: Mpt1981
Ok i have another question.. I may have put the code in wrong...oooppsss!!! now all it says is ERROR. How can i try it again?
Honestly guys im not usually this thick.
Thanks for helping though guys.muchos appreciatos
Username: Bogege
BG
Post Number: 395
Mpt1981 read here for code entry help:http://www.dndservices.co.uk/renault-22dc278-62b.html
Username: Mpt1981
Thank you guys. i no longer have to sing...
