Need code for Holden radio code
Username: Sera
Hi I have a Holden vy radio that needs code. Vin number is 6g17k52b15L39027. Can anyone help me get code?
Username: Regrooster
Post Number: 9821
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
