New member Username: AudiobirdPost Number: 2 Registered: Jan-12 | I am seeking the radio interconnect diagram between the head unit and amplifier/ tuner unit on a 1993 Cadillac. Need the color/ function of the wires. |
Gold Member Username: Joe1234Post Number: 1174 Registered: May-09 | Well any Cadillac? Check out this: 1993 Cadillac Deville Sedan Car Radio Wiring Guide Car Radio Battery Constant 12v+ Wire: Orange Car Radio Accessory Switched 12v+ Wire: Yellow Car Radio Ground Wire: Black Car Radio Illumination Wire: Gray Car Stereo Dimmer Wire: Brown Car Stereo Antenna Trigger Wire: Pink Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 4â³ x 6â³ Car Audio Front Speakers Location: Dash Left Front Speaker Positive Wire (+): Tan Left Front Speaker Negative Wire (-): Gray Right Front Speaker Positive Wire (+): Light Green Right Front Speaker Negative Wire (-): Dark Green Car Audio Rear Speakers Size: 6â³ x 9â³ Car Audio Rear Speakers Location: Rear Deck Left Rear Speaker Positive Wire (+): Brown Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Dark Blue Right Rear Speaker Negative Wire (-): Light Blue |
Gold Member Username: KaerfplSpencerport, NY USA Post Number: 1407 Registered: Jun-06 | Hey K.L.Bird, from what I can tell with the lack of vehicle information, any standard Cadillac from 1993 did not come with any Factory Amplifier. However, if your Cadillac comes standard with the Bose system, then there is an Amplifier connected to each speaker. Each Amplifier will be found and located within the speaker pod/enclosure itself. If the wiring Diagram that Joe Durkham posted above is not for the correct Cadillac that you are working on, check out the web site below for more Diagrams: www.the12volt.com |
New member Username: AudiobirdPost Number: 3 Registered: Jan-12 | Thanks for the response guys. I think I have it figured out. The box that was given me with the head unit by the junk yard dealer was the tuner pre-amp only. I was able to get audio using an external amplifier and will return to the junk yard to collet the individual amplifier modules. |
