I dont know if anyone can help me, but my radio wont work and needs a code the serial no, is CL053110022803 nissan part no. 28113 UK400 also has this no on it PP-1675H thank you sharon
the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
