Clarion radio code clarion pu-2294a? hi i am trying to obtain a radio code for model clarion pu-2294a serial number c70000006424 == CL040161033206C thanks
hi, hope somebody can help me too. i have a clarion pu-2294A SN: CL 040130908796C and I can't find the code for it, please i need help........Thank you
=================== The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
