Username: Mjido5 Post Number: 2 Registered: Oct-11
Saturday, October 29, 2011 - 11:51 GMT my post car is locked,what the solution the decoding ford6000 cd?!!!!!!!!!!!!!!!
Username: Regrooster Post Number: 9111 Registered: Aug-08
Saturday, October 29, 2011 - 14:39 GMT The radio SERIAL NUMBER is required for a code Sometimes pressing buttons 6 & 1 together or 6 & 2 will display your Serial Number Otherwise remove the radio from the dashboard and post the SERIAL NUMBER found on a label on the casing It usually begins with M++++++ or V++++++ -------------------------------------------------------------------------------- ----------------------
Username: Eamonh Dublin 22,
Ireland
Sunday, October 30, 2011 - 13:08 GMT Hi, I have lost my code for ford 6000cd rds e-o-n. My serial number: M194570 Part no.: YS4F-18C815-AC Help would be greatly appreciated!!!
Username: Bogege BG
Post Number: 335 Registered: Dec-10
Sunday, October 30, 2011 - 14:29 GMT Eamonh try code 2682
Ireland
Post Number: 3 Registered: Oct-11
Sunday, October 30, 2011 - 14:46 GMT Thanks a million Bogege, you're an absolute legend!!!
Username: Yos Post Number: 1 Registered: Nov-11
Friday, November 04, 2011 - 15:02 GMT Hi, Have I lost my code for ford 6000CD RDS E-O-N. My serial number: M099201 I would appreciate your help. Thanks !!!!!!!!!
Username: Lethorne1 Post Number: 2 Registered: Nov-11
Friday, November 04, 2011 - 15:43 GMT Hi can someone help me? I need the key code to unlock my ford fusion radio. The serial number is m194716. Thanks!
Username: Regrooster Post Number: 9153 Registered: Aug-08
Friday, November 04, 2011 - 18:11 GMT Lethorne FORD ================================= Duplicate post....Already answered Please do NOT post the SAME request in more than ONE thread It is not necessary....and can cause confusion
Username: Regrooster Post Number: 9154 Registered: Aug-08
Friday, November 04, 2011 - 18:12 GMT re: yos FORD ------------------------------ Try code 8628
Username: Yos Post Number: 2 Registered: Nov-11
Friday, November 04, 2011 - 18:20 GMT Reg Rooster if you only have 1 to 6 digits. as I lay on 8 and 9
Username: Regrooster Post Number: 9156 Registered: Aug-08
Friday, November 04, 2011 - 22:04 GMT Ford Code Entry Instructions Once the unit has been turned on the display will show ' CODE - - - -' Press preset [ 1 ] repeatedly for the first digit Press preset [ 2 ] repeatedly for the second digit Press preset [ 3 ] repeatedly for the third digit Press preset [ 4 ] repeatedly for the third digit To save the code press the [ 5 ] key to accept. The set should now operate.
Username: Lethorne1 Post Number: 3 Registered: Nov-11
Saturday, November 05, 2011 - 14:05 GMT Sorry, i gave you the wrong serial number, its M194796.
Username: Regrooster Post Number: 9162 Registered: Aug-08
Saturday, November 05, 2011 - 15:04 GMT M194796.= 7973
Username: Izsoclean Post Number: 1 Registered: Nov-11
Tuesday, November 08, 2011 - 22:57 GMT Hi, can anyone provide the code for my sisters stereo serial no. M483600?
Username: Regrooster Post Number: 9193 Registered: Aug-08
Wednesday, November 09, 2011 - 00:55 GMT M483600 = 7375
Username: Mason22 Post Number: 1 Registered: Nov-11
Wednesday, November 09, 2011 - 14:07 GMT hi battery went on my ford fiesta so my code is flashing on my radio. the code isnt in the manual and dont have the keys to get the radio out to see the serial number. i have pressed 1 n 6 ant it then flashes up b3 aug 09 then 01339v18255. is this the serial number? its a 4500 rds e.o.n. can someone help?
Username: Regrooster Post Number: 9201 Registered: Aug-08
Wednesday, November 09, 2011 - 15:20 GMT Check this number again 01339v18255 If it is a V serial number then it is one digit short
Username: Mason22 Post Number: 2 Registered: Nov-11
Wednesday, November 09, 2011 - 21:04 GMT i just checked it again. that is what flashes up but the 255 is smaller at the top right hand??
Username: Regrooster Post Number: 9209 Registered: Aug-08
Thursday, November 10, 2011 - 10:43 GMT The radio is going to have to be removed from the dashboard in order to find the Serial Number found on a label on the casing and beginning with M++++++ or V++++++ see instructions here http://www.fitaudio.com/index.php?CategoryID=13
Username: Mason22 Post Number: 3 Registered: Nov-11
Tuesday, November 15, 2011 - 20:04 GMT got the radio out serial number M180489
Username: Regrooster Post Number: 9240 Registered: Aug-08
Tuesday, November 15, 2011 - 23:15 GMT M180489 = 8281
Username: Richie1133 Post Number: 1 Registered: Nov-11
Wednesday, November 16, 2011 - 07:17 GMT Hi i recently changed my battery in a ford falcon and my radio locked i have the serial number 7405742 could any one help with the unlock code Thanks.
Username: Regrooster Post Number: 9245 Registered: Aug-08
Wednesday, November 16, 2011 - 10:27 GMT Richard Monaghan New member Username: Richie1133 Post Number: 1 Registered: Nov-11 Richie1133 posted on Wednesday, November 16, 2011 - 07:17 GMT Hi i recently changed my battery in a ford falcon and my radio locked i have the serial number 7405742 could any one help with the unlock code Thanks. ================================ Sorry....will only be available from the Aussie Ford Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code It will not be available for free or cheap from anywhere on the Internet
Username: Calinmarian Post Number: 2 Registered: Nov-11
Wednesday, November 16, 2011 - 20:02 GMT hi can u help me with a code, please. it is a 6000cd e-o-n. part no YS4F-18C815-AA. serial no M308035. thank you
Username: Garnetl Post Number: 1 Registered: Nov-11
Wednesday, November 16, 2011 - 20:55 GMT Hi, I have lost my code for ford 6000cd rds e-o-n. My serial number: V008917 Help would be greatly appreciated!!!
Username: Regrooster Post Number: 9251 Registered: Aug-08
Wednesday, November 16, 2011 - 23:12 GMT Garnet New member Username: Garnetl Post Number: 1 Registered: Nov-11 Garnetl posted on Wednesday, November 16, 2011 - 20:55 GMT Hi, I have lost my code for ford 6000cd rds e-o-n. My serial number: V008917 ================================== Ford V Serial codes are not available for free from anywhere on the Internet as access is required to the Ford factory database( via a Ford Dealer)...which is not commercially available as software. See your PM message for suggestions
Username: Regrooster Post Number: 9252 Registered: Aug-08
Wednesday, November 16, 2011 - 23:14 GMT calinmarian New member Username: Calinmarian Post Number: 2 Registered: Nov-11 Calinmarian posted on Wednesday, November 16, 2011 - 20:02 GMT hi can u help me with a code, please. it is a 6000cd e-o-n. part no YS4F-18C815-AA. serial no M308035. thank you =============================== Duplicate post....Already answered Please do NOT post the SAME request in more than ONE thread It is not necessary....and can cause confusion
Username: Calinmarian Post Number: 3 Registered: Nov-11
Thursday, November 17, 2011 - 17:53 GMT sorry, i did not know how things work.i won't make the same mistake again
Username: Kaneshka007 Post Number: 2 Registered: Nov-11
Friday, November 18, 2011 - 18:11 GMT Hi...!! Please help me cani find here unlock code for my Ford Mondeo 2001CD/Radio 6000. Serial number is: M247168 Thank you
Username: Regrooster Post Number: 9268 Registered: Aug-08
Friday, November 18, 2011 - 19:34 GMT M247168 = 9893
Username: Racma Post Number: 1 Registered: Nov-11
Monday, November 21, 2011 - 23:11 GMT Hi, I have lost my code for ford fiesta 4500 rds e-o-n. My serial number: M688021 Help would be greatly appreciated!!!
Username: Regrooster Post Number: 9298 Registered: Aug-08
Monday, November 21, 2011 - 23:16 GMT M688021 = 5547
Username: Nermin02 Post Number: 1 Registered: Nov-11
Wednesday, November 23, 2011 - 22:41 GMT hi, i have lost my code for my ford 6000 cd rds eon my serial number is / M094919
Username: Sunnychandi Post Number: 1 Registered: Nov-11
Wednesday, November 23, 2011 - 23:36 GMT Hi I have tried using the code that came from Ford with my manual but it doesn't work. My serial number is M134897 and the code I have is 1684. Hope someone wouldn't mind checking the code for me. Much appreciated.
Username: Jackie111 Post Number: 1 Registered: Nov-11
Wednesday, November 23, 2011 - 23:42 GMT hi iam looking for a code for my ford radio M530391 pin YSF18C815AA thanks a million
Username: Regrooster Post Number: 9313 Registered: Aug-08
Thursday, November 24, 2011 - 10:17 GMT FORD Codes M530391 = 2726 M134897 = 1752 M094919 = 2816
Username: Jackie111 Post Number: 2 Registered: Nov-11
Thursday, November 24, 2011 - 15:46 GMT Thats great Reg Rooster thanks a million
