New member Username: AtownmackAtlanta, Ga Post Number: 6 Registered: Jul-11 | I'm running a dual 4 ohm type r 12" sub on an alpine mrp m500 amp. I have a second type r just sitting at the house because, my amp cant fully push both of them. is getting a second alpine 500W amp, just as much strain on my electrical system as having one 1000W amp? Also what are some good amps to push these dual 4 subs? |
Gold Member Username: Joe1234Post Number: 1068 Registered: May-09 | This can handle 2 type Rs and is very efficient: http://www.audioque.com/AQ1200D-Amplifier_p_30.html Or a second mrp m500 but these are not as efficient. If your alternator is rated 90A or more you can run either configuration without mods IF your electrical system is in good shape. |
Platinum Member Username: GlasswolfColumbia, South Carolina Post Number: 14575 Registered: Dec-03 | You'd be better off (if only barely) with a 1 ohm stable 1200W mono amp like the AQ1200d mentioned above. simpler to wire up, and very slightly less current drain simply because it'll be one power supply instead of two, so your efficiency should increase slightly. |
