Unlock Code For Renault Megane Radio
Username: A_jim_
Hi, my radio is Locked can anyone help me, i have a Renault Megane, the Radio is Tuner List. whit the following data:
Model No: 22DC277/62
RN277F40444924
Prod No FD0304100444924
Thanks.
Username: Regrooster
Post Number: 9289
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
Username: A_jim_
Thanks For the tip Regrooster, there is the rest of data:
T974 Security
8200256141TT974
8200 256 141 --D
Post Number: 9294
try code 6011
Username: A_jim_
Thanks but i can't try it, because when i start mi radio the display have error message, when i press any button sound a bip that's normal but the error message is not, can anyone help me!
Username: A_jim_
Also, the radio in my car is a Tunerl List, as far as i know those cars use an Update List, my car is a megane 2 hatchback 2005 when i purchase it was not connected...
Post Number: 9295
Try leaving it SWITCHED ON...UNDISTURBED for 2 hours or morea and see if it automatically resets itself
Username: A_jim_
Post Number: 7
Thaks man It Worked!!
