Radio code for import Honda S2000
Username: Macsalvage
Hi
Having real problems getting a code for this one!
Turns out the car is an import to the UK so even Honda can't help.
The unit is a Pioneer 39101-S2A-G511-M1.
Hope you can help.
Cheers.
Macsalvage
In case it's needed, the other long ref on the radio is FKTW002349EW
Username: Regrooster
Post Number: 9257
Your only option now is the unit will have to be taken into a Radio Decoding Service where they will connect a laptop to read the code inside the radio's memory chip (EEPROM)
It will not be available for free or cheap from anywhere on the Internet
Thanks for that.
We'll see what we can do!
Cheers
