Need help Honda CRV radio code
Username: Grandpa
Hello, I need help as well,
I purchased old Honda CRV car,radio write COdE, and the sticker with the
code and all dokuments was removed, here are the details.
2005 Honda CRV
VIN is SHSRD87606U404700
Radio Serial is U3004 L8356
( another side of unit info : Honda 39101-S9A-E210-M1
DEH-M6017zh -04
SPEC NO/ XB/EW
SERIAL NO/
EIPE048356EW
PIONIEER CORPORATION
MADE IN BELGIUM
Need only code
Thanks in Advance
Bests Regards,
Liudas
liudas@elekta.lt
Username: Regrooster
Post Number: 9260
The code may be written on the radio or on a card in the glovebox (or similar "hidden" place )
Further suggestions may be found here
http://www.youtube.com/watch?v=tgfRmBo7Pu0&feature=related
Otherwise if you are in the USA try
https://radio-navicode.honda.com/
If the above suggestions are not successful ,then unfortunately the code will not be available for free (or cheap ) from anywhere on the Internet.
Will only be available from your Main HONDA Dealer or a Radio Decoding Service
Useful HONDA Contacts
TELEPHONE NUMBERS
Honda UK 0845 200 8000
Honda USA 1-800-999-1009 (Toll Free)
Honda Canada 1-800-387-5399 (Toll Free)
Honda Aus 1800 804 954 (Toll Free)
Honda NZ 0800 2 46632 (Toll Free
