New member Username: Taylor
Post Number: 1 Registered: Nov-11
Posted on Hi, Please can someone help me out with a code for the stereo in my Renault Laguna 2 2.2dci tourer? Model No. RENRDW103-11 Product No. FD0003270001472 Serial No. RNRD0730001472 Thanks. Taylor. |
Gold Member Username: Regrooster
Post Number: 9255 Registered: Aug-08
Posted on Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode If in doubt post ALL the letters+numbers on any labels or barcodes |
Post Number: 2 Registered: Nov-11
Posted on Security Code is TOD 104 End of barcode reads TD104 Cheers Taylor. |
Post Number: 9259 Registered: Aug-08
Posted on try code 1154 |
Post Number: 3 Registered: Nov-11
Posted on Worked a treat. Thank you very much. Cheers! Taylor. |
