4500 rds e-o-n
Username: Caines1989
hi guys i have a ford fiesta 52 reg mk6
i have a 4500 rds e-o-n car stereo in the car
i dont have the handbook manual
so i dont know the code for the stereo
could someone please help
the serial is:
M 107858
Username: Regrooster
Post Number: 9105
try code 5870
the car stereo it only has numbers 1-6 do you know any other codes?? please thanks for your help
Post Number: 9106
Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
thanks regrooster ill give that a try now by repeatedly pusing 1-4 until the digits are shown then press 5 to save ill let you know if this works thanks for your help
Username: Branko
BelgradeSerbia
Hello everybody,could someone help me with lost code for fiesta 2004.Serial number is M061455.Thanks a lot.
Post Number: 9230
M061455 = 2355
Username: Branko
BelgradeSerbia
Thanks very much Regrooster.
