Do cvr's or any subs require break in?
Username: Mash4kash
Lafayette, LA
Post Number: 350
Do cvr's or any subwoofer require a break in period when new? Is there a smell the first few minutes of playing? Some say a break in period is required some say it's a myth. One guy called kicker and a technician said no. What's the deal??
Username: Nyyfan13
Northern VA
Post Number: 12168
You answered your own question there. To simply put it, again, don't worry about it. I always took it "easy" the first week with new subs just because but it's not necessary.
Username: Joe1234
Post Number: 833
It says in the manual 2 weeks break in period (page 3).
http://www.kicker.com/sites/default/files/2007CompVR.pdf
Not everyone agrees!
Username: Mash4kash
Lafayette, LA
Post Number: 352
So do during the break in period, what you have to watch? Does everything have to be turned off? Bass boost on kicker amp on 0, gain on 1/2, loudness on low, sla on +2, etc.?
Username: Joe1234
Post Number: 834
Just stay on rated power, they will go lower, it's not a dramatic change anyways just a few Hz down.
