What Amp is Good??
Username: Pantera1
Hi, I am new here, and was wondering if I could get some opinions. I have 2 12" wired to 1 ohm Alpine Type R's, what would be a decent amp to run these. My budget is questionable right now, so if I have some ideas I will go from there. Thanks
Username: Joe1234
Post Number: 827
This one is as cheap as I will go:
http://www.sonicelectronix.com/item_22707_Hifonics-HFi1500D.html
Going cheaper does not make sense, I guess I could advice something of questionable quality for $30 or so less.
These are somewhat overrated so it will deliver just enough to top those subs on clean power.
Username: Pantera1
Hi, thanks for the reply, I could probably go a little more, if you know of one of better quality. I have heard of Hifonics, but never heard one. Do you think that's a good match up for those subs?
Username: Joe1234
Post Number: 828
Well next stop would be:
http://www.sonicelectronix.com/item_30078_MB-Quart-Q1.1500D.html
Arguably a little cleaner than the Hifonics. Both will do superbly with 2 type R's.
For power efficiency the Audioque AQ1200D although not everyone agrees that SQ is worthwhile on this amp.
http://www.audioque.com/AQ1200D-Amplifier_p_30.html
Runs cold and go very easy on your electrical system.
Username: Pantera1
Ok, thanks for the choices, I will look into them.
