Hello everybody, I'm looking for the code of my alfa 147 autoradio which serial number is 735387754. Another number under the barecode is 4M+B09j4F B02. Sincerely, William
I can't find any other serial number... My radio is a gps connect nav + from magnetti Marelli. I think there is not a free solution isn't it? I have to try the 10000 code?
Sorry...Magnetti Marelli codes will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code
They will not be available for free or cheap from anywhere on the Internet
