Code for Peugeot 106 Clarion PU2294A
Username: Aticattac
Lost code for Radio,
Any help to get new code would be great.
Serial Number :
CL040110677195
Part Number
PU2294A
other numbers
286-8497-33
96 392 195 80
Car Chassis no VF31CKWU52715228
not sure if any other info required
Thanks
Username: Regrooster
Post Number: 8999
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
