Hi all! i bought a CD player from a scrappy for my 106, its out of a 306 but still fits but is supplied without the code!! its an original clarion unit model PU-2294A SERIAL NO CL0401Z0575035 barcodes: C70000001643 C6CBV0575035 Thanks if anyone knows how to read this, if not the scrapyard said i can get a refund but i have no radio in my car at mo
hi can you help me i have a pug 106 had the clutch replace but the garage took the battery lead of now i have no code for my radio model number is pu-2294A serial number is CL0401Y0149300 i dont even know the make of the radio hope some one can help thanks rob
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
