New subs suggestion
Username: Xradeon
Hi! I'm trying to replace my pair of Kicker L7 12" subs with something better on SQ side..
Here in Mexico is a little hard to get some specific subs.. So far I have the next options:
2 Image Dynamics Id12v3
1 Diamond TDX 15 D4
1 Infinity Reference 1262w (only can get one)
1 Focal Utopia 33wx
1 JL Audio W6 12'
2 Re Se-x 12"
1 Re SE 15" (used)
I want to power them with a MTX 7801 or DB Drive Okur A4 2400D. I have both.
So which one you think is the best for SQ but giving too good SPL?? I'm going to build the box with WinISD.. The max size for the box is 125 liters.
Username: Xradeon
Add to the list 2 MB Quart RWE-302.
Username: Skies
Tofino, British Colu... Canada
Post Number: 950
That Diamond Audio is a 2000w RMS sub, that is way above others listed, you sure you got the right model #?
I'm a fan of bigger cone size vs more small subs myself, would take the Diamond Audio.
Second I would take the JL W6, I've always liked JL's subs.
Username: Xradeon
Here's a pic of the Diamond..
http://bimg2.mlstatic.com/s_MLM_v_F_f_69599008_6445.jpg
Says 750watts..
Username: Joe1234
Post Number: 661
It's a 2002 sub, here are the specs sub/enclosure:
http://www.diamondaudio.com/manuals/tdx_subwoofer_tech_sheet-2002.pdf
It's rated at 1500W RMS it should be 750W per coil. You can put 1200W on it with the DB Drive.
It won't be as loud as two L7 12"s but will be better sound quality and will reach lower notes.
