Radio problems
Username: Dwayne1801
hi, could anyone please help i have a renault grand scenic on a 55 plate i have just getting bk from a garage ive put the radio code 2300 in correctly which i got with the car but it just bleeps then says error is there another code i can use perhaps a default one these long drives with no radio is just to much many thanks.
model no:22dc277/62
product no:fd0002470058195
there is also this code RN277F20058195
Username: Regrooster
Post Number: 8966
Also post the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
hi sorry TN664
there is also TON664 thats all the number/letters its showing thanks for your time
Post Number: 8967
your code is 2300 which is the one you are using.
Make sure you press the final button that stores the code ( ¬ or 6 or 5 ) for at least 10 seconds
