Audio upgrade
Username: Pepo
New York, NY USA
I just bought a 2004 Honda Accord and it comes with a very crappy audio system. I would like to keep the factory radio and replace all the speakers and add an Amp. Any sugection of speaker and Amp, and How can I do this myself?.
Thanks
Username: Mattl
Bolingbrook, Illinois USA
Post Number: 311
First, as we always ask, how much do you want to spend?
Second, the easiest way to toss in an amp is by putting a line-level converter behind the deck. This will convert your existing output to "normal" aftermarket interconnects. Phoenix's TLD22 is very good:
http://www.cardomain.com/item/PHOTLD22
-Matt
Username: Pepo
New York, NY USA
I don't want to spend more that $500. I just want a better sound.
Username: Demigod33
Post Number: 100
i think you should save a little more money, i have a accord '03, trust me you will need to get rid of the factory radio. it kiil the whole sound set. i found out the hard way. there is an in-dash kit on line for $150.00 - it is worth it
infinity perfect 5.25 - $140.00 ebay
<will> lol
dis the rear fill
adire shiva sub- $120ea or 240.00 for two
matt/jon/glass will help you with the amps
Username: Demigod33
Post Number: 101
will fit in the door, i have infinity perfect 6 1/2, i cut a big hole in the door lol
dis the rear fill
