Username: Justone Post Number: 1 Registered: Oct-11
Tuesday, October 04, 2011 - 08:06 GMT MOdel No: 22DC259/62 SN: RN259F40457130 Prod No: FD1004150457130 Security ID: 7700434436TR569 Battery died and code is not in service booklet. Thanks in advance.
Username: Regrooster Post Number: 8860 Registered: Aug-08
Tuesday, October 04, 2011 - 08:08 GMT try code 8480
Username: Justone Post Number: 2 Registered: Oct-11
Tuesday, October 04, 2011 - 08:23 GMT That was speed of light' Thanks, I entered the code, but radio displays ERROR, is ti possible that code is incorrect, or is there a problem with radio wiring, since radio was disconnected and connected again
Username: Regrooster Post Number: 8866 Registered: Aug-08
Tuesday, October 04, 2011 - 08:39 GMT 8480 is the correct code for the numbers given
Username: Justone Post Number: 3 Registered: Oct-11
Tuesday, October 04, 2011 - 09:10 GMT OK thanks once again, will check wiring.
