Username: Nrizvi Livermore,
Ca
Usa
Post Number: 135 Registered: Dec-07
Saturday, October 01, 2011 - 01:30 GMT My Ilink 9500HD is works fine but whenever Scrambled channel pops up on the screen then it stays that way. I have to do hard boot or I have to change my port from 10810 to 10910 and then it comes back. Need help.
Username: Krishn Post Number: 1159 Registered: Sep-06
Saturday, October 01, 2011 - 12:28 GMT If you dont have new fix - may need to update
Ca
Usa
Post Number: 136 Registered: Dec-07
Sunday, October 02, 2011 - 00:05 GMT Hi Subash, Thanks for the reply. I have the latest file of August 11th on my box
Username: Krishn Post Number: 1167 Registered: Sep-06
Sunday, October 02, 2011 - 19:05 GMT I am not sure if you are trying to change between 10810 and 10811 by entering the port on the same server, then you need to do hard reboot. If you put 10810 on server 1 and 10811 on server 2 it solves that problem. The issue is different if you are not watching any channels that require 10811 or 10911
Ca
Usa
Post Number: 137 Registered: Dec-07
Monday, October 03, 2011 - 03:26 GMT Hi Subash, Thanks for the help. Its working now.
