Clarion code
Username: Andydale
Hi , iam new to this but i have bought a second hand fiat scudo van and the radio needs a code but i cant find it ?
Its a Clarion PU-2294A©
and a serial No CL0401Z0519203
Can anyone help me !
Many thanks Andy
Username: Regrooster
Post Number: 8760
the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
Username: Andydale
Ok , many thanks for that. it dont have another bar code so it looks as though i will have to take it in, £ to have it de-coded.
Many thanks.
