Panasonic vs Alpine (Glasswolf, Jon, and other vets!!) HELP!!
Username: Bruhneedluv2
Post Number: 38
PANASONIC CQ-DF903U CAR CD PLAYER versus ALPINE CDA-9825 CD/AM-FM Receiver.
PANASONIC CQ-DF903U CAR CD PLAYER:
High Definition 3D Dot Matrix LCD Display
Rotary Knob
Day & Night Design
Slim Fit Mount
Pre-Amp Outputs dual outputs (5V/60 ohms)
Non-Fading Subwoofer-Out
5V high voltage with low impedance of 60 ohms
CD/CD-R/CD-RW
Sirius Satellite Ready
4-Channel High Power Amp 50W x 4
MOS-FET Output Stage
Spectrum Analyzer
Super Bright Display with Dimmer
Blue LCD Illumination Color
Blue Button Illumination Color
S-HDB (Super High Definition Bass)
CD Changer Control
Track/Disc Scan, Search, Track/Disc Repeat, Random Play
Radio Features
Alphatuner V
18 FM and 6 AM presets with preset scan
Auto preset memory with scan
FMO (FM Optimizer), AFE (Adaptive FM Front End), and INQ (Impulse Noise Quieting)
Muting
Attenuator
Bass, Treble, Balance Fader Controls
Multi-stage Noise Shaping 1-bit DAC
3-beam Hologram Pickup
One-chip Digital Circuit
8x Oversampling (Digital Filter)
CD Controls
Scan, Search, Pause, Repeat and Random Play
AUX Input
Open Face CD Access
Removable Faceplate
Built-in Quartz Clock
Wireless Remote Control
Speaker Impedance 4-8 ohms
Frequency Response (±1dB) 20Hz - 20kHz
S/N Ratio 95dB
ALPINE CDA-9825 CD/AM-FM Receiver:
detachable face
MaxTune tuner
12 FM/6 AM presets
plays CDs, CD-Rs, and CD-RWs
Bass Engine (bass center frequency, width, and level, plus treble center frequency and level and subwoofer level adjustments)
MediaXpander
XM Satellite Radio controls (XM Radio subscription, tuner, antenna required to receive the satellite radio signal.) -- service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
CD changer controls for Alpine Ai-NET changers only
optional auxiliary input
MOSFET internal amp
4-volt front and rear preamp outputs
4-volt subwoofer preamp outputs
clock
18 watts RMS/50 peak x 4 channels (CEA-2006 Compliant)
CD frequency response 5-20,000 Hz
CD signal-to-noise ratio 105 dB
FM sensitivity 9.3 dBf
warranty: 1 year
please let me know the difference between the two
Username: Bigj
which head unit has the best sound quality
Username: Davids2004
Houston, TX USA
Post Number: 398
Ive never had panasonic before. But for SQ im gonna have to say the alpine proably does but we shall see.
