i have a second hand car radio and cd player phillips PH600CY0148483 OTHER NUMBERS ON IT ARE 79 RC800/10 MODEL No79RC800/10 Prod No CG0000370148483 OR 88 It pwers up ok but asks for a code can you help please
If it's fitted in a Renault , Citroen or Peugeot then quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
If not a French car then will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code
It will not be available for free or cheap from anywhere on the Internet
as already stated If not a French car then the code will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service.
