1997 Range Rover Radio Code
Username: Raddodge
I need some help with a radio code. I tried Radio-Code.com, but after $24.95, 6 weeks & about a dozen e-mails back & forth, I've had no luck. The two codes they gave me don't work. 1424 & 26654. This is a remanufactured radio, so it doesn't match the vin#. The serial number is: CR0195V0028418 and the bottom side label is marked:
Type No. PV-9887A & Rover Part# AMR 2672. It is a Diversity Radio.
Any help would be greatly appreciated!
Thanks, Bob
Username: Regrooster
Post Number: 8711
If the code listed on the Clarion database held by a professional decoding service fails to work in your radio then the unit will have to be taken into a Radio Decoding Service to obtain this code.
They will connect a laptop to electronically "read" the working code inside the radio's memory chip using specialist software.
It will not be available for free or cheap from anywhere on the Internet as the required Clarion factory database is not commercially available to buy as software.Sorry
note: I think you will find it is a model PU-9887A
Username: Raddodge
Thanks Regrooster,
I'll start looking for a decoding service in my vicinity.
Bob
