Clarion radio code for peugeot 306
Username: Sharonbarrow
Hi,
the battery on my peugeot 306 has been disconnected and I don't have the radio code, would anyone know what the code would be?
Model: PU9983B
Serial number: 96241480ZL
Thanks, Sharon
Username: Regrooster
Post Number: 8718
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
