I lost my code number
Username: Fiton
I need code for blacker indianapolis be 7923 Serialo No: 24004308
12 Volt EC:102
Username: Regrooster
Post Number: 8619
try code 32361
Username: Fiton
Thank You so much
Username: Noeline
I need radio code for renauld laguna 2001 lost my code
Post Number: 8689
NOELINE
Username: Noeline
Noeline posted on Wednesday, September 14, 2011 - 14:34 GMT
The radio has to be removed from the dashboard
Then quote the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
