2 dish into 1 box?
curious
Can a normal DISH or BEV box (not FTA box) connect to 2 dish at the same time with a switch? Would it work and give all the channels from both satellite?
no
nice try though
curious
hhm.. i think what i mean is like this.
You know how BEV have 2 satellites (Nimiq I & Nimiq II).
Can my normal BEV box get channels from both of that if I have two dish?
MORE CHANNELS FOR YOU
The answer to the second question curious is YES!
