RENAULT CLIO III
Username: Kagura76
Hi
Can anybody help me??? need code for my car radio
8200 483 757T
Thank you.
Username: Regrooster
Post Number: 8510
Sorry.......this is insufficient information
The radio has to be removed from the dashboard
Then quote the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
Username: Kagura76
Oups, not enough information .
This time, it's ok :
RNRD6950322764
RENRDW240-00
F00605430322764
82004483757 E570
Post Number: 8512
try code 3450
Username: Kagura76
Thank you for all.
