New member Username: StafisPost Number: 1 Registered: Aug-11 | please unlock my radio Blaupunkt-werke GMBH beta 815 7 649 204 360 vwz1z2y9334585 6x0 035 152 c * 014vwz1z2y9334585/ * |
Gold Member Username: RegroosterPost Number: 8133 Registered: Aug-08 | Sorry....will only be available from the Main V W Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code It will not be available for free or cheap from anywhere on the Internet |
New member Username: NikosxalkPost Number: 4 Registered: Aug-11 | please i need desperate help with my car radio.. Blaupunkt No:90 533 422 type : car 300 (f) 7 649 852 520 GM030MY5803864 x10 thanks in advance |
Gold Member Username: RegroosterPost Number: 8425 Registered: Aug-08 | nikosx New member Username: Nikosxalk Post Number: 4 Registered: Aug-11 Nikosxalk posted on Tuesday, August 30, 2011 - 23:14 GMT please i need desperate help with my car radio.. Blaupunkt No:90 533 422 type : car 300 (f) 7 649 852 520 GM030MY5803864 =============================== try code 5175 |
New member Username: PolaudPost Number: 1 Registered: Aug-11 | please unlock mi radio gamma 7648231360 BPVWZ1Z3A6611158 |
New member Username: GurikaPost Number: 1 Registered: Aug-11 | please i need code for mu radio blaupunkt car 300 (D) 90 532 620 7 647 852 320 GM300W5117348 made in portugal 2F2 |
Silver Member Username: BogegeBG Post Number: 316 Registered: Dec-10 | Gurika try code 7318 |
New member Username: GurikaPost Number: 2 Registered: Aug-11 | how to write it has namber only from 1 to 6 |
Gold Member Username: RegroosterPost Number: 8436 Registered: Aug-08 | Switch the ignition key ON Press and hold AS button and the ON button at the same time Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed If the display now shows the correct Code number then Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on |
New member Username: PolaudPost Number: 2 Registered: Aug-11 | Good evening voiçi more information for my demand(request) a merçi big saddened you for my English I am French blaupunkt-werke gmbh gamma 8157648231360 vwz1z3a6611158 made in portugal 1j0035186e |
Gold Member Username: RegroosterPost Number: 8441 Registered: Aug-08 | polaud New member Username: Polaud Post Number: 2 Registered: Aug-11 Polaud posted on Wednesday, August 31, 2011 - 15:53 GMT Good evening voiçi more information for my demand(request) a merçi big saddened you for my English I am French blaupunkt-werke gmbh gamma 8157648231360 vwz1z3a6611158 made in portugal 1j0035186e ============================================ Sorry....will only be available from the Main V W Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code It will not be available for free or cheap from anywhere on the Internet |
New member Username: Jamesd5175Post Number: 1 Registered: Aug-11 | Changed battery on my car and now have no radio,any help much appreciated!car 300 E 90 533 422 GM0300X9548935 Cheers |
Gold Member Username: RegroosterPost Number: 8443 Registered: Aug-08 | Jazza New member Username: Jamesd5175 Post Number: 1 Registered: Aug-11 Jamesd5175 posted on Wednesday, August 31, 2011 - 17:46 GMT Changed battery on my car and now have no radio,any help much appreciated!car 300 E 90 533 422 GM0300X9548935 Cheers =============================== try code 5990 |
New member Username: Pantera888Post Number: 1 Registered: Aug-11 | please help. i need code for my caradio blaupunkt car 300 (D) NO. 90 532 620 GM300S2117874 thank you |
New member Username: Jamesd5175Post Number: 2 Registered: Aug-11 | Thank you Reg Rooster, that's saved me a lot of hassle! |
Gold Member Username: RegroosterPost Number: 8445 Registered: Aug-08 | pantera New member Username: Pantera888 Post Number: 1 Registered: Aug-11 Pantera888 posted on Wednesday, August 31, 2011 - 19:40 GMT please help. i need code for my caradio blaupunkt car 300 (D) NO. 90 532 620 GM300S2117874 =================================== try code 7196 |
New member Username: GurikaPost Number: 3 Registered: Aug-11 | its" haven"t display |
Gold Member Username: RegroosterPost Number: 8449 Registered: Aug-08 | re gurika BLAUPUNKT CAR300 ----------------------------------------- If you have no display then just ADD one extra press of each Preset Button for each digit of the code So for code 7318 press the buttons 8429 times Press Preset1 = 8 times Preset2 = 4 times Preset3 = 2 times Preset4 = 9 times |
New member Username: GurikaPost Number: 4 Registered: Aug-11 | Thank you Reg Rooster i will try |
New member Username: GurikaPost Number: 5 Registered: Aug-11 | this isnot wright code |
Gold Member Username: RegroosterPost Number: 8453 Registered: Aug-08 | It is the correct code...but, for some reason , you are trying to use it without a display I suggest you buy another radio( with display AND code ) or a replacement display. |
New member Username: Jibblees7448Post Number: 1 Registered: Sep-11 | Looking for some help! Radio locked up after battery was disconnected, would rather not have to replace it (despite it being older than dirt..) installed in a 1994 Acura Integra Blaupunkt Los Angeles cmd147 werke gmbh BP7443V0476464 (I'm fairly sure there's a V in it, and I'm not sure at all whether it's a zero or the letter O) 7647443510 numerical pad reads number 1-6 only here's a link for a picture, if that helps: http://www.retrevo.com/pdf/548ci668/7/Specifications#q=Blaupunkt+Los+Angeles+CDM 147 thank you in advance! |
New member Username: FdjuroPost Number: 1 Registered: Sep-11 | please i need code for mu radio blaupunkt car 300 90 533 422 7 649 852 320 GM0300X0668046 made in portugal 2F2 |
Gold Member Username: RegroosterPost Number: 8482 Registered: Aug-08 | re GeorGe BLAUPUNKT CAR300 ========================================= try code 9817 |
New member Username: FdjuroPost Number: 2 Registered: Sep-11 | The code is wrong. Thanks anyway |
Gold Member Username: RegroosterPost Number: 8488 Registered: Aug-08 | Sorry..my mistake Try code 4 9 4 8 |
