Which do you think is louder? Just assume each has the reccomended size box and the immortal would be getting 2000W RMS and the 2 flame qs would be getting 600w RMS apiece. Please, someone help me put some shove in my trunk. If anyone else has an alternate sub / amp combo for around this price, let me know also. Thank you.
My car is a 02 Malibu if that helps, and I could give a f#@$ about SQ, i want SPL!
Dang that's a lot of money. I just bought my last car for $1700. I can't believe you guys spend $1000 on just subs and an amp. That doesn't take into consideration the mids/high and the amp/amps to drive them. And the head unit (most already have one, though). And all of the 0 gauge welding cable running all the way to the trunk to power the amp/amps, and the alternator upgrade and multiple batteries, etc. I've seen some pretty impressive CB/amp setups... but $1000 for less than half of the sound... wow.
Well the amp runs at diff Ohms, just thats the most impressive one that amp had. So what kind of setup would you guys suggest for less than a grand or right at? I want violent bass.
123456
i would say 4 sony 12" xplod's with two sony xplod amps and the sony crds2539 headunit. that's probably your best bet. go to www.bestbuyboxes.com and click on the sony section and find the right box. that should all cost about $936.89 so that's about the right price. let me know what you think.
