What 6.5" speakers should i get to replace my factory ones???
i have a chevy 1500 and it has 6.5" speakers in the doors...i wanna get some desent components to replace them...i want the type of speakers that come w/ a crossover network.
i have a pioneer DEH-P6400 HU, what would be a good set of 6.5" speakers to use w/ it, or would i be better off just getting a small amp to push some door speakers???
i looked a infinity 6000cs's....are they any good?
In order for us to make a recommendation you're going to have to let us know what your budget is for this whole upgrade project and possibly some brands you prefer, or how HIGH END you're going to want this to sound.
Oh, and unless your on a strict budget I'd steer clear of the 6000cs's. They're way better than your factory speakers but, well... that's about it.
well my truck is just a daily driver and i just want something better than factory...but no crap like sony!!!
i'm willing to buy on ebay...i dont wanna spend alot...$100-150 max.
i wanna forget about getting an amp to run them on...i just wanna use my HU...it says 50x4 on the face. brand doesnt really matter just as long as its not a crap brand like sony, boss, etc.
