Radio code : Grundig 5201
Username: Heinrich1234
Where would I get the code for a Grundig 5201
Username: Regrooster
Post Number: 8332
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
