Wiring a System
Username: Vbprog40
I have a New Amp and Speakers I got a couple weeks ago. I also have an Infinity radio / speakers.
I want to keep the Infinity radio so I purchased a car RCA Output Converter (Speaker wire = RCA Output)
I need to attach it to the "BASS" speakers located in the doors, however can't run wiring to the doors.....so Does anyone have a Wiring diagram for a 2004 Montero Sport? All the speakers must go to a central wiring harness so I need to find that. The amount of wiring in that car is unbelievable!
Would love your comments on the best way to do this.
-ThankS everyone for your help.
Username: Mattl
Bolingbrook, Illinois USA
Post Number: 229
The wiring harness is connected to the deck, so no trouble finding that. You'll basically be tapping the lines as they go out of the harness, sending them to the line converter, then reconnecting the amp output to the original (outbound) lines.
Unfortunately, that vehicle's too new to really show up on any of the mounting/info pages for more information. So if you can't find an OEM harness converter, you'll have to rewire and reverse-engineer it.
-Matt
