Stereo Code
Username: Bok666
Hi
Bought a used car, previous owner doesnt know the code... i cannot get the stereo out of the car so the only information i have to go on is whats on the detachable numberpad...
its from a Vauxhall Tigra (S reg)
this is all it says
4 660 103 Delco
GM90 493 281
>PA6-GF15<
can you do anything with this or do i have to remove the dashboard?
Cheers
Bok666
Username: Regrooster
Post Number: 8308
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
