Code
Username: Ritasha
hi. i need code to my car 300
serial no GM030041505764
7640852320
Somebody help me please
Username: Regrooster
Post Number: 8104
try code 0 1 0 9
Username: Ccclosh
Hello,
can someone, please, help.
I have Renault Laguna II 2003, and lost my Radio code...
Laguna 2.2 DCi
VF1BG0F0B28444941
I am on vacation and going crazy without music
THANKS !
Username: Hay88
PortsmouthUk
Post Number: 3734
you need to remove the radio.
they are too small holes each side of the radio
use an old metal coat hanger 4 darts or very small screwdriver or long nails.
put into holes about 4-5cms and push outwards sideways
and carefully pull radio forward.
you must do the holes on each side at the same time
Then post the numbers/letters from below the main fat barcode
something like 7700xxxxxxt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
off of the radio
Username: Ccclosh
OK, I'll do that. tnx
Username: Ccclosh
Sorry, wich holes? There are holes in my GPS and small and thin on radio, I try something but couldnt get it out :/
here's a pic :/
Username: Hay88
PortsmouthUk
Post Number: 3737
Should be the four red ones but you may need to do the two blue ones also.
Username: Ccclosh
Finally
I hope this is it, please help :/
TNXUpload
Username: Shazg
Walsall, West midlands
cant get code for vw stereo vwz1z3x8503382 can somebody help
Post Number: 8135
shaz
Username: Shazg
Shazg posted on Sunday, August 14, 2011 - 11:00 GMT
Sorry....will only be available from the Main V W Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code
It will not be available for free or cheap from anywhere on the Internet
Post Number: 8137
ccclosh
Username: Ccclosh
Ccclosh posted on Sunday, August 14, 2011 - 10:32 GMT
Finally
Try code 1 4 2 5
Username: Ccclosh
Sorry, code 1425 wont work, ERROR is on display...
I find something else under radio:
and becouse I am stupid for electronics I tryed 5833 and it writte ERROR again....can you help me, please, I am desperate
Post Number: 8140
ccclosh
Username: Ccclosh
Ccclosh posted on Sunday, August 14, 2011 - 14:42 GMT
This looks like a Renault Alpine radio
If so then sorry....the code will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service
Username: Hpatty
Please help me!! new car and the radio doesn't work wanst given the code as they couldn't find it and haven't used radio since the battery went dead on car 6mths ago it's so boring with no radio
The car is vauxhall corsa 53 plate thee are 2 sticker bar codes on back of it one says
*opel CDR 2005 SN 741376
*DC 409/75 B 161 KW316 3112 328 56435 741377
theres also some no. etched on back which are
*3112.303.3801.2.01-12-01
*38012.cu_a
please help me if you can ;)
Username: Janefryer
SEVENOAKS, NY
My car is finally back on the road - without music Can anyone help me with the code for my Renault Megane?
rnrd6950044706
renrdw240-00
fd01 0513 0044706
serial number 8200 483 757
I woud appreciate any help
Post Number: 8144
Hannah
Username: Hpatty
Hpatty posted on Sunday, August 14, 2011 - 18:51 GMT
*38012.cu_a
Sorry....will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code
Post Number: 8145
janefryer
Username: Janefryer
SEVENOAKS, NY
Janefryer posted on Sunday, August 14, 2011 - 19:08 GMT
rnrd6950044706
renrdw240-00
fd01 0513 0044706
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
Username: Janefryer
SEVENOAKS, NY
This is all that is on there
Hope it is clear enough for you
ThanksUpload
Post Number: 8149
janefryer
RENAULT
Try code 0892
Username: Janefryer
SEVENOAKS, NY
THANKS
Username: Rolake
Hello. Please can u help me unlock my honda radio?
The serial number's B00111159
P/N: 39101-S10-A910-M1
REF NO: MU910A0
I really would appreciate help.
Its my first car and its really so disheartening to think of how to purchase a new stereo.
pleeeeeeeeaaaaaaaaaaaaaaaassssssssseeeeeeeeeeee.....
Post Number: 8160
Your HONDA radio is made by ALPINE...read the following
HONDA RADIOS.................IMPORTANT NOTICE
The code may be written on the radio or on a card in the glovebox (or similar "hidden" place )
Further suggestions may be found here
http://www.youtube.com/watch?v=tgfRmBo7Pu0&feature=related
HONDA do not make radios .They only affix their badge onto radios made by the large manufacturers (ALPINE , BLAUPUNKT etc).
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PANASONIC
PHILIPS
PIONEER
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT.
These will have a Serial Number beginning with BP and another number beginning with
7 *** *** *** found on a label on the radio casing
Plus older radios made by
PHILIPS …Model 22 DC681/02
Early ALPINE (Model numbers beginning CM+ + + + )
UNFORTUNATELY ... NO OTHERS !
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If you can supply all the correct details, then they will be able to supply your code for free.
Otherwise you will have to try your HONDA Main Dealer or a Radio Decoding Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Useful HONDA Contacts
TELEPHONE NUMBERS
Honda UK 0845 200 8000
Honda USA 1-800-999-1009 (Toll Free)
Honda Canada 1-800-387-5399 (Toll Free)
Honda Aus 1800 804 954 (Toll Free)
Honda NZ 0800 2 46632 (Toll Free )
Username: Vwgolf6
I just installed the rns 315 (technisat) or blaupunkt. Bought from demolition company but no code! Please can anyone help? VW RNS 315 EU 3C0 035 279 D VWZAZ2L3367186 SW 0263 HW H31 23/11
Post Number: 8280
Joep
Username: Vwgolf6
Vwgolf6 posted on Sunday, August 21, 2011 - 21:41 GMT
