hi guys i changed the battery of my car nd lost gthe radio code any help wud b great guys 82005051112t rnrc3960012299 renrcw230-10 fd0106480012299 thanks in advance if any1 can help!
Dlee187 code 4454 You must hold at the end to store your code. IF YOU DONT HAVE ¬ KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A¬} KEY
Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ¬] button then rotate the thumb wheel for the correct first digit Press the [ ¬] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL press the first preset button for the 1st digit, second button for the 2nd digit third button for 3rd digit forth button for 4th digit then press and HOLD button 6 to store. for 10 seconds
hi guys need another code if possible it for a peugeot 206 serial number is CLO54242078326J 96552632XT 286-9487-45 H4091004C SORRY DONT NO WHICH NUMBER U NEED SO WROTE THEM ALL DOWN LOL CHEERS IN ADVANCE GUYS
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio===================================================== Reminder :..NO MULTIPLE CODE REQUESTS ON THIS FORUM
Single free code request for personal use only (one code request every 6 months minimum)
This is to prevent abuse by traders+dealers, car radio thieves and other chancers
Sorry if you are one of the honest ones ! ====================================================
