I need to know the levels for my amps
Jay F
My subs sound good but when they start to BUMP they rattle and my friend says check the levels, I got 4 knobs First knob is MAX LEVEL, the next knob is bass boost, third knob is low level and last knob is high level, i know i dont need that one, but i have most of them turned all the way to their fullest and my subs sound like crap, now i know thats the reason but i can't find the right combo for them to sound decent either, thats for the help
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4104
max level is probably your gain.
set that NO HIGHER than half way up.
Set low level to about 80Hz. I don't know the LPF range for your amp so I can't guess at the position for that.
set bass boost to "flat" or minimum. this will only cause clipping.
