Anonymous | i have 2 12inch kicker comp vr subs 2 ohms each i just bought a kicker kx600.1 amplifier. how would i wire this i am new to this so can u please like give me lots of detail. thanks!!!! |
Bronze Member Username: JmloughreyFarmington, CT Post Number: 49 Registered: Jul-04 | just like this
Richard Adams Unregistered guest | well first of all is the amp 1ohm stable if it is you can wire them both together if its not 1ohm stable im not sure what to do, maybe you should have gotten a 2 channel amp and ran each sub on its own channel | |
Bronze Member Username: WardleBrantford, Ontario Canada Post Number: 26 Registered: Jun-04 | this is a 2 channel amp im prety sure | |
Richard Adams Unregistered guest | if its a kx600.1 is a mono (1 channel) amp thats the the .1 means after the 600 if its a kx600.2 then its a 2 channel | |
Bronze Member Username: WardleBrantford, Ontario Canada Post Number: 27 Registered: Jun-04 | well can i get 600watts to each of my subs? | |
Richard Adams Unregistered guest | if the amp puts out 600 watts rms then it will put 300 to each sub, have u found out if its a two channel or a mono yet? | |
Bronze Member Username: WardleBrantford, Ontario Canada Post Number: 28 Registered: Jun-04 | well it says 600.1 so im assuming is 1 channel | |
Silver Member Username: Davids2004Houston, TX USA Post Number: 356 Registered: Jun-04 | Its a mono amp. If you want 600 watts per sub step up to the jbl 1200.1 | |
Silver Member Username: JayjLouisiana USA Post Number: 345 Registered: May-04 | You don't need a JBL 1200.1 it will MELT the coils that will be 400 watts OVER powered. Dave those subs will ONLY take 400watts RMS each for a total of 800watts RMS. You don't want to put 600watts to each sub. Use the Kicker amp you have and wire the subs like this diagram shows. Use option #2 http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/car/subwoofers_wi ring.html?subs=2&impedance=DVC2x2 Davids no offense but you should look up the specs on products before you recommend something that will BURN up what they have. |
Bronze Member Username: WardleBrantford, Ontario Canada Post Number: 29 Registered: Jun-04 | yeah like i said i am new to this and i really have no idea what im talking about haha if i use option 2 how many watts will i get to each sub |
