01 pug radio code
Username: Lizzy
Hello I need a radio code for my 01 pug. not sure the make but the numbers etc are: PU-2325A(B),
286-8497-35, 96 396 920 80, serial number is cl0410y0127338. Many Thanks.
Username: Regrooster
Post Number: 8174
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
