CAR RADIO CODE PROBLEM
Username: Jake151268
Hi ! Have lost the code for blaupunkt car radio 300 (D) ,
No. 90 532 620 , GM1300V4098488 , 7 647 852 320 Radio's been down for 4 weeks b/c battery was disconnected from opel astra '98. Really annoying ! PLS HELP !! & ps advise how to re-set the
applicable code ?? MILLION THANKS !!!!
Username: Regrooster
Post Number: 8274
code = 2533
BASIC INSTRUCTIONS TO ENTER A BLAUPUNKT RADIO CODE
Switch the ignition key ON
Press and hold AS button and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
Many , Many Thanks !! Have turned on ignit., pressed the AS & ON buttons at the same time. Result : Display goes beep , then went to 7 SAFE
What should I do / how long must I wait till code 2533 can be lodged/accepted ?? taking into consideration it is at level 7 due to incorrect codes being previously inserted}
Post Number: 8275
7 SAFE usually means 20 minutes waiting time
note: You appear to be using more than one identity for this forum?
THANKS A MILLION ! RADIO NOW WORKS. MY I.D. = JAKE , I first used i.d. YES but it needed changing
