Radio code for 2001 vauxhall tigra
Username: Garyking
hey i have a blaupunkt car radio witch come with my 2000 vauxhall tigra but it just say's safe when i turn it on. ive taken the radio out and have it with me now. here is what it says\
no.: 90 533 422
type: car 300 (f)
2F2
and the
serieal numer is i think: gm03m y5719819
if you could help me i wouldent no how to thank you enuf ive been driving with no music and its killing me ! lol thanks
Username: Regrooster
Post Number: 8075
try code 5507
To restore from SAFE press AS+ON button and leave SWITCHED ON ...UNDISTURBED until it has automatically reset itself
This may take an hour or more
Username: Garyking
hey thanks for your reply but the numbers only go from 1-6
Username: Hay88
PortsmouthUk
Post Number: 3720
Gary king
code 5507 how to enter.
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
