Slim Mount 6.5 Component System
Username: Gaprofitt
Hi All,
I'm looking for a 6.5 Component Set for my Honda Accord. My local car stereo shop states I need slim mount speakers. What options do I have? I have a 2001 Accord. I was looking into the Polk Audio DB 6500 series. How is the polk stuff? I'm looking to spend around 200-250 and find something that will fit easily.
Thanks,
Greg
Username: Mattl
Bolingbrook, Illinois USA
Post Number: 217
Holy cow, it must be Honda week. See the "Speakers for 93 Prelude" thread:
https://www.ecoustics.com/electronics/forum/car-audio/62417.html
Basically the same thing.
-Matt
Username: Demigod33
Post Number: 92
cut a larger hole in the door
it is easy as 1-2-3
i have perfect 6.5
in the '03 accord i had the same trbl
Username: Audiophiliac
Boise, ID USA baby
Post Number: 22
If you must use "thin" speakers. Look at Kenwood Excelon XR61P or 71P....they are very thin. :-)
